monkey44
Jan 07, 2014Nomad II
westend wrote:
It sounds like the total load is where the problem is, not a single circuit so no need to redistribute or rewire the trailer. The OP states that when the AC is on and all of the entertainment devices in use, a breaker trips. By putting the AC on one phase in a 50 amp load center and putting those outlets most used on the other phase, the problems should cease. Configuring a 50 amp load center is all about balancing out loads.
I don't come near to using all of my 50 amps nor is there an imbalance on one leg. Just like residential wiring, distribution is the key.
That is the simplest answer - redistribute the load.
If you add an additional sub-panel somewhere convenient (you only need one power lead to it w/ground), you could run the electronics all from it. All you'd need is a few wires run and a few plugs for those items separate.
OR, another option, plug a small surge-breaker panel and power it from the 20a breaker on the power pedestal -- Best run it thru a surge protector). That will separate all the electronics from the rest of the RV. This is probably the least expensive way. If you install one surge-protector with eight plugs and a battery back-up (we have one that cost $80), you can run eight small units off it (like phone chargers and X-box, laptops. And all it needs it a 20a feed, even a heavy-duty extension cord - those devices you're talking about use very little juice each. So, plugging into one power unit will give you enough.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
