SCVJeff
Aug 04, 2014Explorer
Phydeauxman wrote:you're prettymuch committed to this hose then unless you buy the QD's and build your own. Personally I don't mess with LP crimpsmguay wrote:
In order for the grill to work halfway decent you will have to remove the regulator on it that the green tank screws into. The RV has it's own regulator on it already and it won't work being double regulated. I removed the regulator on the grill and connected the hose directly to the grill.
That sucks...commits the grill to the camper. Wanted to be able to keep it whole in case I wanted to use it with a 20lb bottle.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
