NJ6PACK's avatar
NJ6PACK
Converter / Charger question
Please help me understand my converter / charger in my TT
2007 R Vision Max Lite TT ML 28RS
Atwood model # TP3-55530SS
I was de winterizing the TT the other day and I got a new battery (battery date code was 3/17) because the other one was shot
I hooked up the new battery and after about 12 hours of being pluged into shore pwr I wantted to test the new battery
Before I unplugged the TT shore power this was the reading I got
Is this a normal reading on a new battery? (the top LED was flickering on and off)
When I unplugged the shore pwr this was my reading
Are these readings normal?
This Atwood unit will charge a battery if it needs a charge correct?
.....I realize these readings are coming from the same unit that always says my black tank is full
  • Seems low. For best diagnostics you really need a voltmeter.
    Converter should hold voltage about 13.6 and the battery should hold 12.65+ when charged and disconnected.
    Either way your battery would appreciate a modern 3 stage converter.
  • Normal for a battery that is not fully charged.
    Do you have a voltage meter and do you know how to use it?
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
