Workinprogress's avatar
Jun 03, 2019
Charger/Converter questions...
I recently purchased a 2007 Fleetwood Gearbox, and have discovered this weekend that it has TWO charger/converters installed... one is a Magnetek 775 and the other is a PD9130. The PD9130 appears to be an add on, and the magnetek appears to be original. There is a battery cutoff switch installed in the trailer. I have 12v power in the trailer with the switch off while the generator is running, but NOT while plugged into shore power with generator off.... if I turn on the switch, I have 12v at all times obviously.
Why would someone add a second converter, and is this a common practice? Also, would they both be benificial, or should I do away with the older one and just run the PD9130? I'm a newbie with converters and have only seen one per vehicle in the past...
