hmknightnc
May 26, 2014Explorer
smkettner wrote:
Stops charging and loads up the generator? 1000+ watts of heat in the small box should release smoke in a minute or less. Must be something else going on.
Are you sure the battery is OK?
Does the generator run the electric water heat OK?
Could it be a fuel filter?
X2. You'd smoke that converter in a matter of minutes or trip the circuit breaker
