Hi folks my issue is my 110v works for my fridge A/C and microwave - but plug ins for coffee pot (all of them) do not work with shore power or generator. I have replaced GFCI it has light on GF indica...
First, the converter converts 110vac to 12vdc. Since your 12v is good, your converter is good.
Breakers can go bad but I suspect that something else is going on. Maybe a loose wire??? Do you know which breaker powers the receptacles that don't work? If you have a voltmeter check the voltage and see where it stops.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 20, 2026
