Hi folks my issue is my 110v works for my fridge A/C and microwave - but plug ins for coffee pot (all of them) do not work with shore power or generator. I have replaced GFCI it has light on GF indica...
With a voltmeter check the load side of AC breakers in ON position to verify power goes thru breaker.
IF it does then you will need to find 1st outlet in string and check it for voltage.......then the next one and next one etc.
If breaker good then one of them outlets has loose connections.......rv outlets are cheap junk that use a strip with notch that wires are just pushed into. Very easy for them to come loose.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
