kevin21ExplorerApr 25, 2013Converter ?Hi folks my issue is my 110v works for my fridge A/C and microwave - but plug ins for coffee pot (all of them) do not work with shore power or generator. I have replaced GFCI it has light on GF indica...Show More
tenbearExplorerApr 25, 2013I would guess the 30A breaker is the master breaker and the 15A and/or 20A breakers are fed through the 30A.Are the non-functioning outlets fed by the GFCI?Be careful, 115v can kill. In case you don't know, the black wire is the hot wire. Check voltages between the black and white wires.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
Related ContentNo 12 Volt without converter80 amp converter and eu2000iIOTA DLS-45 converter and LifePO4 batteriesUpgrading converterConverter Issue?
