kevin21's avatar
kevin21
Converter ?
Hi folks my issue is my 110v works for my fridge A/C and microwave - but plug ins for coffee pot (all of them) do not work with shore power or generator. I have replaced GFCI it has light on GF indicating wired correctly. Looked at breaker panel I have a siamezed 15/30 amp breaker both on the on position - still no worky to 110v plugs. Is it posible 15 amp breaker is faulty? I have recycled/on off several times - still noworky!rrr very frustrating.Help!
12v is fine - 110 plug in is not.Is it the converter (Magnetec Series 6300 Model 8332)
Kevin
  • Odd for the light to be on and no power. Have you checked voltage?
    Did you try the coffee pot in the microwave outlet?
  • First, the converter converts 110vac to 12vdc. Since your 12v is good, your converter is good.
    Breakers can go bad but I suspect that something else is going on. Maybe a loose wire??? Do you know which breaker powers the receptacles that don't work? If you have a voltmeter check the voltage and see where it stops.
Having RV issues? Connect with others who have been in your shoes.24,203 PostsLatest Activity: Feb 20, 2025
