enblethen
Aug 24, 2013Nomad
Could be normal.
You could have a failing battery.
What voltages are you actually seeing on the input?
Normal should be right at 120 volts. As input voltages drop, the amperage will increase. There could be a poor connection in the shore power system which could be in connection point all the way to the converter or where you are taking the readings.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
