BFL13's avatar
BFL13
Explorer II
Aug 22, 2018
Converter on Low AC Input Example
Converter specs say 105v minimum to work right. On 15a long extension cord from house, running 75 amp converter on low batteries, was getting 56 amps as constant amps instead of 75.
Voltmeter said "120" in RV receptacle circuit the converter was in while running was 99.8v. So the converter does work below that 105v, sort of.
Fired up the Honda gen and plugged RV into that and amps now 75.4 with 120v up where it should be for converter specs.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
