ken_burke's avatar
ken_burke
Converter and Battery Isolation Switch
All . . . . .I have a 2011 Cedar Creek 34SB. I am still checking out my converter. (lights are flickering)
During normal operation, I leave the Battery Disconnect Switch in the "ON" position (keeping the batteries in the charging system).
The question is: Is turning the switch to the "OFF" position the SAME thing as going to the batteries and disconnecting the batteries??
What will the converter do when putting the switch to the "OFF" position? What will the conveter do when disconnecting the batteries (leaving the switch on the "ON" position).
thanks all . Exactly where is the converter located in the 2011 Cedaar Creeks?
ken
  • I would take the batteries down to your local tire/auto parts house and have them load tested (it's free). Even a bad battery will often give you a decent voltage reading right after you disconnect from converter/charger.
    If the light fixtures, ground wires, batteries etc all check out then I suspect your converter might be failing. Not expensive to replace - some/many consider Progressive Dynamics to be better converter - easy DIY install.
    Good idea. I might have a battery problem. With the batteries connected, the DC lights go bright, then dim, then bright, etc, at 1 minute interval. With the battery isolation "OFF" (batteries disconnected) the converter voltage is constant and dthe lights do not change.
    ken
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
