MEXICOWANDERER
May 26, 2016Explorer
But unused means abandoned. Why would the converter be howling at the moon? Look into a Battery Minder or Battery Tender, connect the gizmo directly to the posts then chop all loads with a battery switch. I too use battery negative.
The rig converter takes a nap. The only AC power is going to the maintenance charger. Safer, and more secure. Good on you for having a load disconnect if indeed it chops ALL power returning to the battery. :)
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
