TNrob's avatar
TNrob
Converter breaker trips when battery disconnected.
If I plug the camper in while the battery is disconnected the breaker for the converter trips. If the battery is connected and I plug in it does NOT trip the breaker.
Normal? Nowhere to dump the start up juice maybe?
  • My disconnect is on the negative post. I don't find any leak from frame to positive.
    Can't help but disconnect. 30 some years says batteries sitting unused get switched out or disconnected. Old habbits.
  • Could the positive cable for the battery be touching something or have a nick in it that causes a fault to ground. Assuming you are disconnecting the battery using the positive cable
Having RV issues? Connect with others who have been in your shoes.24,368 PostsLatest Activity: Mar 11, 2026
