- TNrobExplorerMy disconnect is on the negative post. I don't find any leak from frame to positive.
Can't help but disconnect. 30 some years says batteries sitting unused get switched out or disconnected. Old habbits. - darsbenExplorer IICould the positive cable for the battery be touching something or have a nick in it that causes a fault to ground. Assuming you are disconnecting the battery using the positive cable
- MEXICOWANDERERExplorerPretty much tells a person to NOT disconnect the battery - dont'cha think?
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
