Maybe this drawing of my WFCO 8900 series Power Distribution Panel is easier to read.
This is installed in my OFF-ROAD POPUP unit and has the WF8945 Converter/Charger unit in it.
I originally purchased this unit but never could get the WF8945 converter to go into smart charge mode so wanted to replace it with a PD9260C converter/charger unit.
Since the WF8945 was brand new I just couldn't pull it out and throw it away so I left it in place and added my PD9260C unit closer to my battery bank. With this setup I can use either the WF8945 unit or the PD9260C unit by flipping the 120VAC circuit breaker ON/OFF for the unit I want to use.
This leaves the WF8945 unit really a back-up unit in case the PD9260C fails.
NOTE I am using two bus bars grounded to the chassis ground but the NEUTRAL BUS BAR is isolated from ground. It gets its return to ground back inside the camp ground pedestal.
Keep in mind to follow the NEUTRAL ISOLATION and CHASSIS grounded items real close to get it right.
All of my ROMEX cables HOT-NEUTRAL-CHASSIS GROUND are on one side of the power distribution panel and the +12VDC and -12VDC(ground) are wired on the other side of the distribution panel. Except for the BATTERY (-) cables I run two (+12VDC and -12VDC) wires to each of my 12VDC items. I use what is called "BOAT CABLE" that has BLACK and WHITE wires inside the covered wiring cable.
All three wires coming from the camp ground pedestal must be used as this is the only way the trailer frame is grounded from lightning strikes etc...
Roy ken
