tenbear
Jun 19, 2016Explorer
There are several types of converters. Most older converters and many OEM converters output a single voltage in the 13.6v range. Modern converters are usually 3 stage and the voltage output depends on the battery charge state. The output voltage when the battery is discharged is in the 14.4 to 14.8v range and the voltage drops to about 13.2 when fully charged.
For a quick check without using a voltmeter, unplug the RV and turn on a few lights. Then plug in the RV and see if the lights get brighter. You will probably need someone else to plug in the RV while you watch the lights.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
