BFL13's avatar
BFL13
Explorer II
May 29, 2013
Converter In-Rush Thermistors etc, UPDATE -4
UPDATE on 17 Nov, Update 2 on 22 Nov, Update 3 on 16 Jan 14,
Update 4 on 19 Oct 14.
In a recent thread there was mention of how you can wreck your gizmo (in my case a converter) by turning it off and restarting it again before the capacitors have finished unloading----if I was understanding that discussion.
So I am worried I am going to wreck my nice PowerMax 100 amp converter doing that.
Background is that last year I had one of these and had the top off so I could adjust its voltage with the internal pot they have. Somehow at one point after some weeks of using it, the in-rush current thermistor burst into flames and that was that.
PowerMax sent me a new "beefier" thermistor which they said would also be used in the newer 100 ampers. I got that in and had that going for a while and then I think when starting and stopping and restarting right away (maybe that was it, not sure) that thermistor over-heated and fell to bits.
I am wondering if it was operator error in starting/ stopping sequence that did for both thermistors.
I do see on the voltmeter that after you shut off the converter (when disconnected from battery), its voltage tapers down for a good time rather than drops straight to zero, and from the discussion mentioned above, I understand that is the capacitors "unloading." So now I am wondering if I blew the new in-rush thermistor last year by restarting the converter under full load of 100amps too soon?
The in-rush thermistor seems to be on the 120v input side while the capacitors that unload are on the DC side some distance from the thermistor on the circuit board so I am not sure how they relate.
BTW PowerMax was kind enough to help me out replacing my ruined converter and I now have a fancy new prototype ( I guess) version with an external voltage pot this time. I promised not to take the top off and poke around inside it :)
However, the way I do my recharge, it can happen that say the Honda pops its breaker due to other loads added besides the converter, and I restart the Honda before the converter capacitors unload. Even with a normal start, the converter sometimes makes a snap sound like my big inverter will when disconnecting and connecting, which is capacitors according to folks here who have commented on that. (except how can the converter ones snap on start-up if they are already unloaded?)
I have been using this new 100amper for a while now and nothing has gone wrong. But I am scared to death of screwing up my nice converter by some sort of mystery operator error if that is what it was. I can't avoid "doing it again" when I don't know what I did!
Thanks
