BFL13's avatar
BFL13
Explorer II
Feb 08, 2020
Fridge Thermistor Replacement Question UPDATE (Fixed)
Updated 10 Feb. and 14 Feb
My 641 Norcold cools down too cold and won't shut off. It is not in back up power--the temp light does not flash.
I have not yet fiddled with the light/thermistor to see if it is just a bad connection.
There is a replacement part available. As a temporary fix if fiddling doesn't help, can I swap out the sensor (snip the wires) and replace with an old Dometic 6 cu ft fridge's sensor (splicing in its wires to the Norcold's)
AFAIK it is all about the resistance of the sensor, but no idea what the circuit board would think.
http://rvrefrigeratorrepair.com/wp-content/uploads/2016/08/Norcold-Service-N61x-N81x.pdf
Thanks
