BFL13
Feb 12, 2020Explorer II
wnjj wrote:BFL13 wrote:
Interesting description on the manual of how the Temp settings work, using the thermistor readings and timing protocols. I see the timing is to have longer time with cooling on and shorter time for cooling off as you go up from 1 to 9. They use "duty cycle" for that in percentage of time on.
I’m not sure if I found the same place but what I saw in the manual discussing timing based cooling was only for Backup Operating System (BOS) mode. That is only in use if the thermistor fails.
Yes, the timing info I quoted was from the manual for the NX models I had linked earlier, but it must be the same for the Ns like mine and others with Temp Settings.
I don't know how they can co-ordinate the warm up "off" times with when the fin actually gets that warm to trigger the thermistor R values that restart the cooling for each setting. Perhaps they just use whichever comes first?
