Stude55Dog's avatar
Stude55Dog
Converter issue
Have fifth wheel on 50 amp service. Am now on 3rd converter. Yesterday we had fake fireplace on and the breaker on box tripped. Turned fireplace off, turned breaker back on and smelled smoke, went outside and the converter was emitting heavy smoke. Unplugged, went got another converter, make sure fireplace was unplugged, installed converter, turned breaker back on and it smoked that converter immediately. Not sure what to do next as it is weekend, cant reach mfg. for advise. Need to figure out as we live in trailer. Would appreciate any guidance or suggestions. Thanks
  • ppine's avatar
    ppine
    Explorer III
    Take out your fake fireplace and replace it with a beer cooler.
  • Get one of these. It should show for issues. I agree sounds like open neutral. Likely in your shore power cord connector.
    Tester
    Meter inserted into receptacle blades, may show excessive voltage or even 240 volts.
  • If you don't have a 2nd voltmeter, go ahead and tighten all the connections in the breaker box. It can't hurt and it may help.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    From the sounds of it you have an open neutral. When you turn on the fake fireplace the voltage changes on teh two legs. Now SOME converters will deal with that. others do not.
    Use not one but TWO volt meters. one plugged into an outlet that is one Leg #1 and the other on Leg 2 and observe voltages.. Should be right close to 110-120 but if one climbs to say 150 you have an open neutral. (the other will drop).
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
