bjkb1fExplorerApr 09, 2019Converter IssueEDIT - I've since found out I have a WFCO WF-8735 or 40 and I believe I have the info I need to test it. Thank you all! Can anyone tell me where the converter is on a 2018 Coachmen Apex nano 193...Show More
ppineExplorer IIIApr 09, 2019Usually the fuses are on the front of the converter. Check your main fuses.I had an older hybrid from 2002 with a single stage charger. I replaced it for less than $200 for a four stage charger. Much better.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
Related ContentTowing lights issueConverter Issue?No 12 Volt without converterConverter/ Furnace IssueWeekend Warrior Converter Issue
