tcrespo's avatar
tcrespo
Converter Issue?
I have a strange situation in my new (to me) Class A. 2003 Georgie Boy Landau with 12V Converter located in the basement.
When I plug into shore power, I want to put my batteries into store mode but still run the AC out in the driveway. If I leave the switch in "Use", everything works great; If I flip it to "Store", the AC will turn off.
I'm assuming that the thermostats are 12V powered and also assumed that the converter takes the 12V power and sends it to the coach, regardless of the battery switch setting.
I've checked the converter - when it's turned off, I read 12.6V at the output (which is the power coming back from the house batteries); When I turn it on, it goes to 13.8V, so I know it's outputting DC.
Am I missing something somewhere? Everyone tells me that I should be able to put the batteries into store mode but still use the 12V from the converter.
Very confused...
Having RV issues? Connect with others who have been in your shoes.24,313 PostsLatest Activity: Sep 08, 2025
