dennislanier's avatar
dennislanier
Converter issues
Have a couple questions about my converter. Jayco class c with Iota dls45 converter. I really plugged in to shore power about 2 hours ago and the converter fan is still running don’t recall it running that long before. Could the constant fan be a sign of the converter failing? It is probably the original one in this 2004 mh. I checked the voltage at the battery and it read 12.7. Voltage at the output of converter read 13.0. Any help appreciated before I head out next week.
  • BFL13 wrote:
    dennislanier wrote:
    Just thought of something else I read earlier. If I turn OFF the battery disconnect switch and stay plugged in to shore power the 12v lights go out. If the converter is working shouldn’t the lights stay on with shore power?
    Yes, IF the converter is also getting 120v input while other 120v things are. You can check for that too.
    EXCEPT--if the converter is on the other side of the battery so it supplies the 12v fuse panel across the battery and uses the same wires to the panel as the battery, so now the disconnect will cut off the converter's 12v too.
    Don’t know exactly what you mean here. How can I tell if the converter is on the other side as you say?
    The tv and microwave are getting 120 volt power with battery disconnect off. I just tried it again and the 12 volt lights went off.
  • Just thought of something else I read earlier. If I turn OFF the battery disconnect switch and stay plugged in to shore power the 12v lights go out. If the converter is working shouldn’t the lights stay on with shore power?
  • Take the wires off the battery and measure the voltage at the battery posts. Leave the converter plugged in to 120v and measure the "12v" output of the converter with no battery attached.
    What is the battery? Can you take hydrometer readings? if so what are they for each cell? You might have a bad battery instead of a bad converter.
    BTW. look for a telephone jack socket on the Iota. If there, you can get an IQ4 for it. If not, consider a new converter that can do 14.x volts in a Bulk stage.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
