BFL13
Dec 18, 2019Explorer II
agesilaus wrote:
Yeah I was sitting here thinking about it and figured out I had it backwards. I'll do that tomorrow.
If the two 6s you have connected now are at 10.78 I would not leave them like that another minute. (They might already be toast though.)
An hydrometer will remove all mystery as to the SOC of the batteries, regardless of what the voltage is saying for whatever reasons.
WRT above, whyinheck would you pay over $200 for one of those, when you can get one of these for $136 that has adjustable voltage so you can do anything the battery specs want? 6s want 14.8ish normally and 16ish every so often.
https://www.boatandrvaccessories.com/products/powermax-pm3-60lk-12-volts-60-amp-power-converter-battery-charger-w-led-light
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
