ScottG
Dec 18, 2019Nomad
If I understand correctly, your question was about sizing the new converter. Since you have two sets of 6V's, I would go with something like an 80A to 100A unit. However, that also depends on whether you plan to use a generator to power it and recharge the batts. If you have one of the 2000 watt inverter gens then you're going to want to stick with nothing bigger than a 60A converter.
If you go with one of those bigger converters, you'll probably need to upgrade the wires to your batts.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
