BFL13
Dec 19, 2019Explorer II
Hope you didn't jump the gun there. Never heard if there was indeed 120v to the converter or if its RP fuses were good. If not, then the new one won't work either.
OTOH, I suppose we should assume you did all that stuff and that's that.
You still need an hydrometer to confirm your smart charger got the older 6s back up. Also you need the hydrometer to show that you got your new 6s up to proper SG after they have been sitting on the shelf however long at the store.
Beware of paralleling the new 6s with the old 6s if the old 6s don't prove out with the hydrometer test.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
