agesilaus
Dec 21, 2019Explorer III
OK here is where I smash a carton of eggs on my face. I got the new converter and took a look at it, the power cord is not what I expected: a lug to put a heavy cable into. No it's a regular power cord with a 3 prong plug on back. To say that was a surprise is no exaggeration.
I cut a hole in the panel under the sink to try to see this converter and was contemplating pulling the stove out to gain access to the thing. I had tugged on the converter end of the power cable to see if it was loose but it seemed firmly attached, which it was.
After this discovery I went out and pulled the other end finding a loose 3 prong plug! *&($$#@!!
Anyway the silver lining to this is that you can return stuff to Amazon no questions asked. I still don't know where the thing plugs in but using an extension cord has it running for the time being until I find the right spot which seems to be at the bottom of the furnace somewhere. I'll put my boroscope to use and find it.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
