BFL13
Dec 21, 2019Explorer II
You have an opportunity at this stage to plug the converter into a power bar with its own switch where you can get at it, and plug the power bar in somewhere.
That will give you an easy way using the power bar's switch to turn off the converter if you are ever on an inverter "whole house".
In some rigs you can't just use the converter's circuit breaker, because it shares that breaker with the receptacles you want to stay live on inverter.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
