wa8yxm
Jan 11, 2019Explorer III
The short detector on the slide out controller should be post-controller (motor side).
Sounds more like a very bad connection or batteries past end of life.. IE.. When my Original hit 9 years old they had relatively little capacity (30%) of what they had when new.
Batteries have several failure modes. One is HIGH RESISTANCE this can be Mimiced by a dirty connection (high resistance connection) and on my chassis battery that happened 3 times... That sounds like what you got.
Loss of capacity.. that is also a failure mode. a 200 amp hour battery is down to 50 or less
And shorted cell.that is the bad one because with shorted cell it never comes UP and the non-shorted can boil dry.
OH speaking of boil dry.. Check the fluid level (IT's not water) and if needed add DISTILLED WATER to the mix.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
