RoyB
May 13, 2013Explorer III
Before you call the converter dead you might want to make sure it is getting 120VAC on its input. No 120VAC input - No 13.6DC output...
Since you saw 3VDC it is most likely dead but would be nice to measure 120VAC on the input just to be sure. Also there should be a circuit breaker in the 120VAC circuit breaker side of the power panel for the converter. Probably the second one down...
You might want to consider a different smart mode technology unit to replace the WF8945 unit. The WFCO units are prone to not go into smart mode charging when you want them to. The Progressive Dynamics PD9245 or PD4645 unit should slip right into to the same spot where the 8945 unit is installed and hookup the same. Probably same cost as well...
just my thoughts
Roy Ken
just my thoughts
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
