ksg5000
May 13, 2013Explorer II
saronabound wrote:
Ok, I found the PDF file for the converter. I followed the troubleshooting. Disconnect the battery cables from the battery.
Plug in Shore power and check voltage at the battery cables.
This turned out to be about 3v dc. So the converter is shot.
I will buy a new one. Just the guts though. Thanks for all the input.
saronabound
There is usually a fuse/circuit breaker between the battery and converter (located near the battery) - before buying new converter make sure the problem isn't a few dollar breaker than needs replacing or resetting. In my rig it's an auto reset circuit breaker.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
