gillis's avatar
gillis
Converter problem
Hello , I am having a problem with a WF- 8835 converter . It will not charge my battery and it none of the 12v systems work . I have checked all fuses , they are good . I removed the wires from the converter and checked the output which was 13 volts not 13.6 like the manual says it should be . So should the 12 circuits work even if the battery is out of the unit ? Also is the 13 volts good enough to charge my battery? Currently nothing on the 12v side is working .
Please help Thank you
Bill
  • If you have 13V at the converter, you should have the same voltage on your battery. If you don't, one of the wires from the converter to the battery is not tight.
    In my case, it was the negative wire on the converter negative bus that was loose.
    If you can connect pieces of wire to the positive and the negative at the converter output, use your jumpers to take first the negative to the battery. If that helps, it's the negative that is loose. If when you connect the positive it helps, look for a loose positive connection.
  • Not sure but I believe with the converter DC output disconnected it is in float as it feels no current draw. Pretty sure converter will power 12v without a battery. With everything connected and something 12v on like he range hood fan what is the voltage at the converter?
    - Jeff
  • It doesn't make sense that you have 13 V output but your 12 systems are not working. Look for a battery disconnect switch. 13 volts is not up to specification so the converter needs to be replaced. It will never fully charge your battery. WFCO converters are not known to be good battery chargers. Go to bestconverter.com to find a quality replacement, Randy will fix you up. I don't know what kind of camping you do but I would recommend a Progressive Dynamics replacement.
Having RV issues? Connect with others who have been in your shoes.24,346 PostsLatest Activity: Jan 09, 2026
