KcBorne's avatar
KcBorne
Converter question. PD 4655 Vs. Powermax boondocker
My PD4655 went out last night and it is still under warranty. I called Bestconverter to get it replaced, and the tech Randy is suggesting the Powermax boondocker as a replacement. I notice the PD4655 retails at 205$ and the Powermax Boondocker at about 160$. I know higher prices isn't always better quality, so i want some advice on weather to stick with the PD or go with the PM. Thx
  • The Boondocker also is a 4 stage charger-4th stage is pulse desulfation/maintenance mode.
  • Thanks for the replies. This camper stays plugged in on my property, and is used for a live in camper. I don't even have a battery installed. So it charging isn't an issue for me.
  • Either is fine depending on usage and expectations.
    For mostly plugged in they are both the same.
    For fast charging from a generator the Boondocker will drop out of boost at about 75% charged where the 4655 should hold boost four hours and get you to ~90%.
Having RV issues? Connect with others who have been in your shoes.24,240 PostsLatest Activity: Apr 29, 2025
