iski4fun wrote:
Good day, 1999 Fleetwood Travel Trailer 25 ft - does this rig have a converter? My interior lights were getting dim even when plugged into shore power. This prompted me to search for a converter to possibly replace because I understood a failing converter could be the culprit (due to not adequately charging the 12v). I couldn't find one, just a basic panel with 12v fuses and breakers for the 120v. I'm wondering if this rig even has a converter. Replaced 12v batteries which helps the dim lights, and I'm keeping them charged with a trickle charger. Is it possible this rig does not even have a converter and the 2 systems are separate? Note: interior lights on the 12v do not turn on at all when batteries are disconnected. Thanks, Bill
You found it I suspect. You said "Just a basic panel with 12 volt fuses and Circuit breakers" In Every RV I have been in that has a panel like that the converter is behind the panel.. What is the make/model of the panel.. Two common makes are Parallax and WFCO.
The Parallax 7300 (note spelling may be off) is an intergrated SINGLE stage converter/fuse/breaker panel. 7300T is a two stage. NOTE I say 7300 but it's 73xx with the xx being the max output.
WFCO is a 3 stage with a high failure rate but it should still float. Just not Bulk charge.
Also check for one or more 30 amp fuses. they may be blown.. if so unplug for a few minutes. then replace ALL the 30 amp fuses and plug back in
