iski4fun wrote:
Pics uploaded now - the panel assembly pictured sits inches off the deck - nothing is below it. Is the converter part of this entire assembly? Would it be connected to that thick red wire which I assume is 12v positive from the batteries? I've pulled this assembly out and haven't seen an obvious converter. Thanks!
You have the Model 80 which is just the AC and DC panels. Your converter will be mounted somewhere else. Could likely be a PD 9100 deck mount behind or near that panel.
http://www.bestconverter.com/Parallax-80D-30-Amp-ACDC-Distribution-Panel_p_86.html#.X7r_x-mSm44www.bestconverter.com/9100-Series-Deck-Mount_c_39.html
