CA Traveler wrote:
The function of a charger is to charge and maintain the battery and wire loss is also a factor. The charger therefore should be close to the batteries or be connected with larger wire.
On this CA we agree it should be as close to the batteries as possible (But not in the same air space)
On My coach it was dang near as far away as possible (To be farther it would have had to be inside the "House" part and not in the basement) Batteries were right, near front, under steps.. path went through battery control center FRONT over (in front of firewall) Converter Driver's side rear wall of rear most compartment .... What were thy stinking? I don't know. but for sure not thinking
