Gene_Ginny
Feb 06, 2016Explorer
jcrhea wrote:Yes it may change the brightness a little. I hardly notice it in my unit even when I see the change on the voltmeter on the wall.
... So if I replace my converter board with the direct replacement PD 4655 unit, my voltage to my lights, etc in the house will change from ~14.4 to ~13.6, down to ~13.2 as the charger runs through the stages, correct? Wouldn't that cause the lights to change brightness?...
The biggest factor in how fast the battery(s) charge is the size and length of the wire from the converter to the batteries.
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Aug 08, 2019
