time2roll
Feb 06, 2016Nomad
13.6 is about the top of the normal range and is fine. Could cause slightly more water usage in hot 100+ temperatures.
WFCO is supposed to drop to 13.2 after a few days of storage. Often this function works as well as the boost mode.
Yes there will be a slight change in brightness for an incandescent bulb. But once you swap to LED it is fixed by an internal regulator. No more brown outs either when running just on battery as it dips to 12.2 and below.
PD4655 is excellent.
The 12 Volt Side of Life
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Aug 08, 2019
