MEXICOWANDERER
Feb 09, 2016Explorer
I've had a WFCO 55, operating for 2-years into an AGM. 13.2 float is an impossible dream. Forget it even exists.
When the battery is cycled, 14.4 volts appears for a few seconds upon startup. Even though the Lifeline is at 50% or thereabouts. Cable? You gots to be joking.
I used the original cables from WFCO. Short, with soldered battery-end leads. The WFCO is powered off line voltage which too is monitored.
Every one of them (WFCOs) are dopplegangers to Hungarian movie actresses. They're all freakin' insane, and therefore there is no "norm".
I read somewhere above that a "smart converter model" charges at 14.8 volts? Oh yeah? For how many seconds? Ten? Thirty?
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Aug 08, 2019
