bigfootford
Aug 27, 2016Nomad III
carriemiller wrote:
Thanks lynnmor
The fan is controlled by the load that is on the converter, not temperature. Turn off all unnecessary 12 volt items and let the converter charge the battery, it may take all day. Turning off the breaker shuts down the converter. <<
makes sense. Appreciate your info. :)
Not all converter fans run because of load.... Some run because the converter temperature gets above spec... Others are like you said..." Fan is controlled by the load".
Example:
Progressive Dynamics = thermal
WFCO = Load
Jim
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
