- wa8yxmExplorer IIIThanks for letting us know the outcome. Far too many do not.
- carjockieExplorerThanks to all, both house batteries were bad, the converter works fine.
- wolfe10ExplorerWe need to wait for the OP to get back to us with FACTS as asked in the very first couple of responses!
- BFL13Explorer IIIt could even be a PowerMax LK left in its single stage adjustable mode at say 14.8v instead of being put over to its three-stage mode.
Or whatever he has, the fan is stuck on so he thinks the converter is on high, and it only at 13.6, but that is too high at his ambient temp.
Too bad he won't tell us anything. - What is the battery voltage while charging? And the voltage after resting disconnected 12 hours?
Could also be battery is shot or low on water. - BobboExplorer III
wa8yxm wrote:
There are basically 3 types of converters and a few sub types
Some like the old Magnetek were "Dumb" and would indeed over charge batteries boiling a wet cell dry in as little as 2 weeks.
THen we have the "Single Stage" normally 13.6 Never shuts off. never reaches full charge either Example Parallex 7300 not T. Now if these are set wrong they can also over charge.
Then we have the multi stage (2 3 or 4) Assorted types of these.
Parallex 7300T (T for Two--stage that is not the song) this one does a timed BOOST mode. some may do it on a voltage sensor... THey can (in theory) hit full>
FInally we have 3 stage BOOST, Absorption, Float
Boost is a higher output voltage to push lots of amps once the battery voltage rises amps drop to ABSORPTION (the last 10 percent or so) still 14.5 or so volts (Exact may vary) but amps are in the single digits.
Finally it goes to 13.6 (Float) and sticks
A bad part can keep that last step from happening.
(Or the other two depending on the part)
So what's it doing.
oh the 4th step. Equalization, a timed precision over charge. How it'd done depends on the make and model Some you need to push one or more buttons. some (Progressive Dynamics Charge Wizard) Do it all on their own.
Float on the better units is about 13.2v rather than 13.6v. The old Parallax/Magnatek did 13.6v. - wa8yxmExplorer IIIThere are basically 3 types of converters and a few sub types
So what's it doing.
oh the 4th step. Equalization, a timed precision over charge. How it'd done depends on the make and model Some you need to push one or more buttons. some (Progressive Dynamics Charge Wizard) Do it all on their own. - YC_1NomadIf a large DP with a Magnum converter the temperature sensor on the battery can cause issues. Unplugging the sensor will resolve the issue.
- LwiddisNavigatorAnother satisfied new person.
- Sam_SpadeExplorerAs was said, not enough information.
The converter is SUPPOSED to run constantly, dropping to something around 13.3 Volts to "float" the batteries when they are fully charged.
If the voltage really stays much higher than that seemingly forever, then only two real likely causes: Bad converter or worn out batteries.......or after a while on a bad converter, maybe both now.
