BFL13
Feb 03, 2021Explorer II
ivbinconned wrote:
Yes I guess I should have. Normally I do. Guess I am getting lazy.
If I have to replace the converter is there a converter that is compatible with wet as well as Lithium?
And is there any reason to go higher in amperage?
This works with any battery spec, voltage adjustable, perfect for LFP.
60 amps is good for a 100AH LFP above 41F. From freezing to 41F you need a lower amp charger like 15 amps so use a regular car battery charger or whatever till the battery warms up.
https://www.boatandrvaccessories.com/products/powermax-pm3-60lk-12-volts-60-amp-power-converter-battery-charger-w-led-light
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
