time2roll
Feb 04, 2021Nomad
ivbinconned wrote:Progressive Dynamics does have a "Lithium" converter and some have a "Lithium" jumper to change the charging pattern. However all this does is to lock the converter into the 14.6 charging mode continuously. This is not recommended by lithium battery manufacturers. You would have to charge and then disconnect. Fine if you use a generator and are present while charging finishes. Not so good to just plug in and go out for the day.
The Dynamic line up does not have one that does both acid and lithium.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
