mpvuk's avatar
mpvuk
Converter voltage drop
Just replaced lead acid with LFE (200ah) and want to change converter to a lithium specific unit. Current unit WFCO WF-9855. My LFE's suggest a 14.4v bulk charge. Converter's I'm considering all bulk at 14.6v.
Do I take voltage drop into account when determining bulk charge at the battery? And will a 14.6v at converter work in my situation?
I have 6g on an approx. 10' one way run between battery and converter. New converter will be a 45A model. A 1.5% drop will bring 14.6v down to 14.4v. Based on my limited knowledge, I'm thinking I'll have at least a 1.5% drop.
Also note that I'm planning on getting a 45A unit to replace the WFCO 35A. Am I correct that current wiring will handle that?
Thanks in advance for your input.
  • theoldwizard1 wrote:
    Any QUALITY converter/charger will have a specific setting for LiFePO4. Use it !
    Personally, I would just eliminate the converter and buy an inverter/charger/automatic transfer switch.
    New to this so hopefully replying in proper format...all LFE specific converter/chargers I've found have a 14.6V bulk phase. My battery mfg says to stay at 14.4 or less in bulk. Are there LFE chargers that start at 14.4? Regarding an inverter/charger, I already have a 2200W pure sine wave inverter that Works great. My best value seems to be using existing inverter and upgrading the converter.
  • Any QUALITY converter/charger will have a specific setting for LiFePO4. Use it !
  • time2roll wrote:
    #6 wire is good to at least 60 amps.
    Depends on the cable length.
    I ran the OPs numbers quick and 45amp would pull it down to 14.16v.
    I don't know if that's too low compared the 14.4v recommendation.
    Of course if the amps tail off at 10amps, it's up over 14.5. I don't know if that's too high.
    It does seem logical that voltage drop is taken into account but how much variance can be allowed is really the question.
  • mpvuk wrote:
    . . . I have 6g on an approx. 10' one way run between battery and converter. New converter will be a 45A model. A 1.5% drop will bring 14.6v down to 14.4v. Based on my limited knowledge, I'm thinking I'll have at least a 1.5% drop . . .
    Based on the voltage drop calculator I'm using, a 10 ft (one-way) run of 6 awg at 45a will result in a .36v, 2.47% drop at 14.6v. This is best case and assumes all connections and terminals are properly tightened and crimped. Everyone has their own personal preference in terms of an acceptable voltage drop. We typically strive for less than 2%. YMMV.
  • Yes the PD can be manually controlled with the Wizard.
    I wonder if the WFCO would have done better if the battery was lower on charge. Always a new odd story on WFCO that never seems to operate as they would have you expect.
  • I went with a Boondocker (75A for 315AH) because it's output is dialed to what you want.
    The BMS does most of the management.
  • Thanks all. I did try the WFCO and it supplied 14.4v for a few minutes before going to 13.6v. Not a good option to quick charge with a generator.
    Regarding the PD 9200 series (non lithium)...I can use the charge wizard to bulk at 14.4v and hold it there for 4 hours. If before that 4 hour period is up and the battery is ready to absorption, will the PD move off the bulk phase?
    For most part, will be zapping battery with generator for a few hours at most. So will still be in the bulk phase. But If I want to fully charge, will the PD9200 do that if I use the charge wizard set to bulk at 14.4 and absorption at 13.6, or will I have issue as the WFCO and bulk cuts out after a few minutes?
  • 3_tons's avatar
    3_tons
    Explorer III
    You might consider converting the WFCO to something better and more compatable:
    https://battlebornbatteries.com/product/progressive-dynamics-lithium-replacement-converter-section-for-electronic-power-center-55-amp/
    3 tons
  • I do not recommend 14.6 volts to charge LFP batteries. Especially with a converter that can hold this voltage for an extended period. Use the converter rating directly, no adjustment for voltage drop should be used.
    I would avoid WFCO if spending money. The existing WFCO will not hurt the LFP battery but may not charge at the 14.4 boost level and simply remain at 13.6 volts. This will charge the battery fine but slower than necessary. Fine for the first trip or two if needed.
    Consider a PD9200 series (standard, not the lithium)
    https://www.bestconverter.com/9200-Series-Deck-Mount
    45 or 60+ amp is fine depending on the wire that connects to the battery is sufficient for the additional power. And the battery must be compatible with the full amp rating for charging. Some are limited to 50 amps.
  • It's up to you but with my expensive Lithium battery I follow the manufacturers recommendations to the letter and measure at the battery. I question the need to move to 45 amps. The old 35 will fill the battery very quickly IMO.
Having RV issues? Connect with others who have been in your shoes.24,308 PostsLatest Activity: Sep 03, 2025
