Old-Biscuit
Oct 11, 2013Explorer III
The WF-8930/50 is a WFCO AC/DC Distribution Panel.....used for either 30A AC service OR 50A AC service and 12V DC.
The converter positive is attached to one of the lugs at top of DC Fuses (should be 2nd from left next to battery positive cable) and converter negative should be left of DC Fuses on vertical terminal strip.
The converter is located behind panel.......with a WF dist. panel you have a WFCO converter.
You can test converter output while on Shore power and battery disconnect off....with 110V AC in converter output should be 13.6V DC.
Contact BestConverter.com for replacement and better info.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
