If you read posts by me you will see when it comes to converters I tend to preach a theme
IF you have a magnetek 6300 UPGRADE
If you have a Progressive Dynamics Intellapower 9200 with optional dongle or 9180 with optional Wizard THERE IS NO UPGRADE.
What does that have to do with this thread.
The converter the ignorant ignoramus who wrote that article is the Magnetek 6300 he described it very well, and as I said if you have one UPGRADE.
Modern 3-stage plus converters do not have two different converters and a relay in the box
They have one big converter, and a voltage sensor and a current sensor and some control electronics.
If they sense a low battery they increase their output to rapidly bring the battery up to near full (80-90 percent) During this time charge rate will taper some,, then they switch to a slightly lower voltage to continue to fill up the last few percent,, Still monitoring both voltage and current when they sense the battery full they drop to a "Float" mode, where hopefully NO current flows in the battery. The PLUS part: Some monitor temperature and adjust voltages to make sure they are precisely full, Some will pop in a short "Equalization" charge after a period of time which also seems to improve battery life. Some have other special features, Some combine special features.
But well.. Friend of mine, author of a song or two I've sung, recorded and E-mailed back to her,,, (She likes my voice, I like her lyrics) just got a new phone,, Samsung Galaxy S-5. Today's multi-stage converters are as to that Magnetek the article reviewed, as her phone is to... Well Look up a Military communications device PRC-6. About the same comparison.
