tealboy
Sep 12, 2017Explorer
GordonThree wrote:
Running electric water heater on generator is going to consume most of the power even from twin 2000w Honda (4kw peak, 3.2kw continous) WH probably wants 2.4kw... you won't be able to run AC and WH at the same time.
Water heater is not problem, uses 1500 watts and only takes 45 min to make it very hot. Good for 3 moderately quick showers. I don't leave it on, no need to.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
