RJsfishin wrote:
And did you know that if one 6 volt battery has 220 amp hrs, that two of those same batteries connected in series, still has only 220 amp hrs ? But that is still probably double the amp hrs in your single 12v battery.
Also be informed if you are thinking of using a lot of battery power to operate such things as hi powered sound system, and you are expecting solar to keep up w/ recharging, you will need to be thinking 4-6 more panels added to what you have.
Theres a 400aH 6volt lifeline I'm looking at, so two of those wired in series should should be plenty for now.
I'm not going to rely on solar to recharge completely, I'll have the engine running most of the time it's blasting music, and it will only run 3-4 hours at night, charge all day kind of thing.
