Vic.Bc wrote:
RJsfishin wrote:
In my case, I left the old converter where it is inside the power center.. I just disconnected the 120v ac wires to it, and brought them to a new receptical to plug my new deck mount into. Then just hook up pos and neg cables
Beauty, I think I understand now. So the power Center and all the breakers will still be the exact same, too cool.
I have a small compartment a couple where my current 12volt battery is now which I'm thinking would be perfect for a deck mount. I don't know the exact measurements but I would say the compartment is just over a ruler in length, same width as a Costco 12volt deep cycle and you could probably stack two batteries on top of each other for height.
Would this be considered a deck mount?
http://www.bestconverter.com/PowerMax-PM4B-60-60-Amp-4-Stage-ConverterCharger_p_413.html#.U7CtcIm9LCQ
Yes, that is a deck mount converter. The converter shouldn't be in the same compartment as the batteries because of possible explosion. The battery compartment should be vented. The converter should be connected to the battery with at least 6 gauge cable, as short as possible.
